ford falcon manual transmission w/overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2011, 09:20 AM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I saw two of those transmission in a garage. If anyone Subject Matter Expert (SME) Ford falcon, I have shop manual, the manual stick/no overdrive up to 62. Maybe they made with overdrive in 63 to 65, even with later. I have a overdrive in my garage.
While looking on two of those transmission, I crawled under transmission of my 6 cylinder. My transmission has 450,000 and getting sloppy. My Ford F-100 short box. I made a pattern of the multi holes. The three speed as most of all with 8 bolts on toploader with short case. The falcon with 6 holes on the bellhousing using had a another (Falcon)? transmission to fit, but it has a pinion is fixed shaft output. I don't know about the driveshaft, is it a slip to the 3rd?
I have pictures of what I have.
Old 08-13-2011, 09:30 AM
Footstomper
Pictures
Every people like to see the real thing in picture!
Ford manual transmission 70's brainsboy Transmission - Rearend 1 03-11-2009 01:08 PM
93 Ford Ranger Manual Transmission problems Triaflo Transmission - Rearend 1 08-28-2005 07:58 PM
Ford L6 to V8 manual transmission MartyMart9@aol.com Transmission - Rearend 1 02-16-2005 05:32 AM
Ford 6 Speed Manual Transmission nightrain_rod Transmission - Rearend 0 12-24-2003 10:28 AM
54 223 Ford 3 speed manual transmission Neal0o Transmission - Rearend 0 09-17-2003 11:55 AM
