ford fe 390 Draft tube or pcv? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 03:12 PM
62galaxiguy's Avatar
Hi guys& Happy New Year.I just finished my mild 390 rebuildCrane 901 hyd cam 9.5 to 1 forged pistons complete rebuild heads moly rings trw bearings etc stock 4bbl intake & 4100 autolite 4 bbl w/ FPA ceramic coated long tube headers& pertronix ign.Since this is mainly a cruiser (no racing) Should i go with the stock draft tube or convert to a pcv system? I dont want to drill holes in my brand new finned offy valve covers.I dont care about pollution(my car is exempt in NJ)I just dont want blow by and oil mist in my brand new painted engine bay.Thanks Fellas,Mike
Old 01-01-2007, 03:38 PM
ColoradoKid's Avatar
Draggin main
[QUOTE=62galaxiguy]Should i go with the stock draft tube or convert to a pcv system?
Mike I too have a 62 galaxie. This is a g code 406 car and has the stock tube. The engine compartment is very detailed and I have had no issues with a mess and or blow by. I dont see anything in your build that would create excess pressure. I dont blame you on the valve covers....those things aren't cheap!
Old 01-01-2007, 04:09 PM
Yeah
your right206.00plus 10.00 shipping from P A W.Mike
Old 01-01-2007, 08:40 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
run a hose from the draft tube to the airclener base (smog cars have tons of hose fittings in the base, I guess one would swap right in place of original); routing it around for a clean appearance?
Old 01-01-2007, 11:05 PM
aka Duke of URL
What type of road draft tube provision do you have on the rear of the intake?
This is the early type and shows a PCV conversion. You do not need breathers in the rocker covers. It draws through the oil fill tube at the front of the intake (needs open breather cap).
Old 01-02-2007, 08:10 AM
pcv=much more effective way to get rid of moisture and nasty corrosive gases that condense and form in the motor every time it gets cold.....like every night whether you drive it or not
back in the "draft tube" days....recommended oil change was every 2,000 miles (oil is contaminated)....motors needed a re-build much sooner even with 2k oil changes (especially rings)....a part of the reason for both.....the draft tube and slow in town driving
Old 01-02-2007, 05:22 PM
Draggin main
hmmm.....good information to know. My car is done original except lowered and wheels so the oil change intervals is good to know. Thanks
428 heads for a 390 Fe Crazy_John69 Engine 9 11-08-2011 06:21 PM
Ford 390 CustomFord Engine 16 02-09-2008 01:20 PM
Ford 390 (piston in the hole) goatman-68 Engine 7 01-13-2003 05:31 PM
Looking for Ford 390 connecting rods geobarn Engine 3 09-15-2002 04:30 AM
Ford 390 rebuild...What's the best year?? Bo_Jangles Engine 3 03-01-2002 04:02 PM
