Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ford fe 390 Draft tube or pcv?
Old 01-01-2007, 03:38 PM
ColoradoKid's Avatar
ColoradoKid ColoradoKid is offline
Draggin main
[QUOTE=62galaxiguy]Should i go with the stock draft tube or convert to a pcv system?
Mike I too have a 62 galaxie. This is a g code 406 car and has the stock tube. The engine compartment is very detailed and I have had no issues with a mess and or blow by. I dont see anything in your build that would create excess pressure. I dont blame you on the valve covers....those things aren't cheap!
