Ford FE engine in a Shoebox Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2008, 06:01 PM
Does anyone have any information on installing a Ford FE series engine in a 1949-1951 Ford Shoebox?
I would like more power and reliability than a modified flathead but want to stay relatively period in the engine swap. I don't want to go the common SBC or SBF route. I am thinking an updated 390 with aftermarket heads would make a good stout swap and still be more Ford and period than the other obvious alternatives.
Any information on fit, frame mods, clips, engine compartment sheet metal would be greatly appreciated along with transmission recommendations. A 5 speed or a 4 speed auto would be nice.
Will not be a racer, just a good strong street car.
Thanks in advance.
Harley Monster
Old 02-14-2008, 06:21 PM
techinspector1's Avatar
Wiki Edits: 326
The problem is not gonna be fittin' the motor, it's all the other stuff that has to be upgraded: cooling, steering, suspension, brakes, rear diff, etc., etc.
If I were gonna do it, I'd be lookin' for a derelict 66-69 Fairlane, Comet or Falcon to use as a donor car. I'd cut the front and rear frame thirds off the '49 and weld the Fairlane/Comet/Falcon front and rear subframes onto the middle part of the '49 frame. That way, you'd be set up for motor mounts, trans mount, radiator mount (using the donor core support), newer power steering and suspension and brakes, rear suspension and differential, etc. You could also set the body to the height and attitude you wanted it at without having to fosdick around with cut springs/dropped spindles, etc. and the attendant evil handling that comes with messin' up the suspension geometry. A motorless donor that came with an FE would be a plus, giving you the good diff. Headers might be difficult to come by with power steering, but I'm thinkin' a set of Sanderson shorties would work. Crites sells a plan to convert to disc brakes on the front for $25. It uses OEM stuff that you can find in the boneyards.
http://www.critesrestoration.com/fairlane.htm
For the skinny on the myriad of other stuff involved, I'd get one or more engine swap books and bring myself up to speed.
http://www.amazon.com/Engine-Swappin...3034763&sr=8-1
http://www.amazon.com/Complete-Book-...3034834&sr=8-2
http://www.amazon.com/Practical-Engi...3034834&sr=8-3
Old 02-16-2008, 08:45 PM
junkyardjeff's Avatar
I have seen a 460 in one so a 390 should fit,I would recomend installing something like a fatmans front clip to make it easier to install the motor. The original suspension is made so the motor has to have a center sump oil pan and making one for a FE would be difficult,you might have to use the 6 cylinder radiator brackets to move it in front of the core support for more room. Jeff
Old 03-01-2008, 02:17 PM
RetroJoe's Avatar
Beats pickin' cotton
My 50' has a 302 in it and it is a tight fit! I don't know who installed it, but it works!
Ford GT-40 Crate Engine Questions 31rdster Engine 8 11-27-2005 03:32 PM
MSD Pro-Billet Ford FE Distributor tomcasino Engine 4 09-22-2005 06:03 PM
What can I do to hop up this 197 hp 460 Ford engine onebadmerc Engine 7 05-25-2005 12:05 AM
Ford Engine size Rancher Engine 6 11-23-2003 01:45 AM
Ford Engine Sizes bigjoedo Engine 1 01-31-2002 05:05 PM
