Ford FE valve cover clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 04:51 PM
Anyone ever run Harland Sharp Roller Rockers under the factory
stamped CJ valve covers? The cam lift I'm using is .560" , just
trying see if anyone has experenced valve cover clearance problems.
I'd like to keep my 428 CJ as stock appearing as posible.
Zeal
Piston To Valve Clearance Problem - Help leejoy Engine 85 02-24-2008 06:12 PM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
SBC valve cover ventilation questions? frankenvette Engine 1 08-25-2006 04:18 PM
roller rocker and valve cover clearance 56madmook Engine 5 03-24-2003 02:53 AM
Valve Cover Breathers trick66 Engine 1 03-17-2003 08:46 PM
