Ford FE Vs. MEL - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 08:47 PM
Ford FE Vs. MEL
I was just wondering what the differences are between a FE and a MEL?
Thanks
Old 01-15-2011, 10:10 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
FE- Engines for, Fords & Edsel's
CID's 332 352 390 406 427 428
MEL= Engines for, Mercury, Edsel, Lincoln
CID's 338 410 430 462
Rich
Old 01-15-2011, 10:29 PM
Been a long time since I looked into those, but I don't think any of the parts
interchange either? Aren't the MEL engines a whole different engine, block and all? Yeah, looks like it by the below info.
http://en.wikipedia.org/wiki/Ford_MEL_engine
Old 01-15-2011, 11:31 PM
JeffB's Avatar
Still a lot of parts available for the FE's not so with the MEL's.MRE books has a good book on Ford interchanges you may want to pick up if you are considering a build.
Old 01-16-2011, 03:19 PM
Originally Posted by richard stewart 3rd
Hi,
Rich
There was an FE 410 that I believe was only put in a Mercury. If memory serves me correct I think it had a 390 bore with a 428 crank. I'm also thinking that there was a 383 MEL.
Old 01-16-2011, 03:48 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Your memory serves you correctly, the 410 was an FE, can't say about a 383 MEL.
1997 Ford Ford Ranger gear ratio ? mercury man Transmission - Rearend 8 03-23-2008 02:10 PM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 02:00 PM
1998 Ford F-150/1957 Ford Delivery Sedan Dennis Anderson Introduce Yourself 1 12-29-2006 06:10 PM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 08:14 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
