Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ford flathead carbs
Old 05-24-2002, 04:04 PM
ThosLeete ThosLeete is offline
Dont plug the power valve in the primary carb its function is to enrich the fuel charge when the vac drops off (power valve) use the center carb as the primary and then run progressive linkage to the #2 carb so it acts like a passing gear---the best of both worlds power and economy.Also a word of caution you will find that if you run both carbs straight up the back cyls will over-fuel and the front ones will starve or run lean--been there done that...tom
