ford fmx kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2011, 07:43 PM
ford fmx kickdown
Hi i put a fmx behind a 302 there is no room for the kickdown rod. is there a way to convert to a cable (holley 4bbl) thants bill
Old 06-02-2011, 08:11 PM
tnsmith10's Avatar
when will it rain???
that trans has been put behind v-8's before so, either youve got the wrong kickdown rod, or its setup is wrong. unless theres after market stuff available for the fmx, it never came with a cable for kickdown.
Old 06-02-2011, 08:58 PM
ford fmx kickdown
Thanks for the reply. this is a 49 merc replica and the engine is to close to the firewall, the rod wont fit. I thought a cable would be easier than moving the engine forward. thanks bill
Old 06-02-2011, 11:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cable would be easier. You may have to fab up the brackets.
Lokar sells a cable kit for C4 - C6 trans. maybe it is workable for the FMX
Old 10-05-2011, 06:26 PM
Lokar sells a cable kit for FMX too!
Old 10-05-2011, 07:21 PM
I have lived without it, been downshifting manually, getting used to it. but it's time to do it right. thanks for the reply. bill
Old 10-05-2011, 11:55 PM
4 Jaw Chuck's Avatar
The kickdown tube is similar in quality to large diameter steel fuel line or even electrical conduit. I have fabricated custom linkages using the original ends soldered onto custom bent tubing on a few occasions with copper couplings, use silver solder for the best results.
Seamless fuel line gives the best results for a complete linkage mockup and bends with the tightest radius, of course this all assume your carb has the proper linkage to begin with. Make sure it is the right length before you solder it all up as there is limited adjustment at the carb linkage.
If you want a factory look use fuel line ( 3/4" I think) and squeeze the ends in a smooth jaw vice like a milling machine vice. Then you can drill the proper size hole and insert an off the shelf plastic bushing available from any auto supply store, but using factory ends can look nice as well just make sure the soldered couplings are close to the ends and give it a shot of silver paint to hide the copper couplings.
Good luck with your project.
— Han Solo
Old 10-06-2011, 06:50 AM
Irelands child's Avatar
Use a Lokar cable and save yourself time and trouble.
This is mine with a Loker cruise control cable as well:
As a note, FMX like Ford's C4 and C6 has several different trans mounted kick down levers. You may have to change it out to work with a cable.
Dave W
Irelands child
T-400 kickdown kit for forty ford Footstomper Transmission - Rearend 1 07-22-2010 09:37 AM
700 r4 kickdown arizray Transmission - Rearend 4 12-16-2009 05:05 PM
C4 A/T kickdown NewMustangfan Introduce Yourself 2 08-24-2007 01:44 PM
Ford C-4 Kickdown Question Z-Money Pit Transmission - Rearend 2 10-11-2005 03:34 PM
What does a kickdown do? ratfink14 Engine 19 07-11-2003 01:24 PM
