Ford's filters are very touchy. The tool must be fully inserted just right before you pull on the filter. There is a ring in the fitting on the fuel line with retainer clips that like to twist and bend easily. They make metal disconnect tools that work best but cost more. Here is a link to what the metal tools look like, page 2 - FTLD4 part #,tools . If you damaged the clips in the line you will need to forcefully remove the filter and then some of the times you can remove the metal retainer ring from the fuel line fitting and replace it (some Ford dealerships stock them) or you may need to replace the whole line.
Well, I finally got the filter off the Explorer. The tools I purchased just wouldn't release the internal line clips. I finally got them to release by cutting the filter body off the lines and picking the clips loose with an old game chicken fighting spur I picked up from a friend a while back. It's a long snap-on metal spur I hear they use in rooster fighting. It did the job! Too bad the dirty filter wasn't the problem with the SUV. Oh well, on to the next Ford challenge. Thanks!
