If memory serves me, Fords didn't have a resistive fuel sender back in the 6 volt days (pre-1956). Instead, they had a cycling style sender that pulsed like a gauge regulator, except the pulse rate would change as the fuel level changed. Similar to how temp senders work on Ford flatheads. I could be wrong, maybe Ford started using resistive fuel senders before they switched to 12v electrical, but if yours is a cycling style sender, it will not work right with an aftermarket gauge.
I would buy a fuel gauge that comes with a new sender. Most aftermarket gauge sets come with all the proper sending units for fuel, oil pressure and engine temp. Hope this helps... |
Fuel sender
I am working on a 1947 CJ2A Willys. The gas gauge in it did not work. I checked the sender for ohms, and it is infinite all through the range. The sender is bad. The jeep has a 6 volt system.
The parts guy I get a lot of stuff, from said he needed to know if the gauge used high resistance for "full" or low resistance for "full" I pulled the gauge out of the Jeep, and hooked it up to a six volt battery, and 25 ohm potentiometer, and used that to check if the gauge worked. It did, and about 0 ohms was "full" The gauge was not damped, it moves immediately when the resistance changes. Modern gauges are damped, they move slowly, they use a heated spring to move the pointer. |
Fuel sender
Thanks JoeG.
You are exactly right, it is not a normal sender. I found my shop manual and it confirms much of what you said. I also dropped the tank (no gas in it yet) and pulled my sender and checked it with an ohm meter. NO linear variable resistance; it changes, but with no real consistency. Thanks for the info and the advice, I will look for a guage and sender that are compatable with each other. Any suggestions on a brand or good (cheap) place to buy? Thanks again.........Mike |
I am really not sure about all the details on a fuel gauge sender on a vehicle older than I am, but I suspect the sender might of has a fairly smooth change in resistance when it was new, or at least newer.
| Fuel Tank Sender.. requires earth? | duncan_m | Electrical | 2 | 08-02-2008 12:02 AM |
| fuel sender conversion | 7Dart2 | Electrical | 5 | 06-06-2008 11:22 AM |
| fuel sender part# | grandpaws 57 | Electrical | 1 | 07-19-2007 04:21 PM |
| Ford 1 and 2 piece fuel pump eccentrics | lluciano77 | Engine | 17 | 10-09-2004 10:58 PM |
| Replacing fuel gauge sender question? | Jag Daddy | Electrical | 23 | 10-23-2003 11:55 PM |
