ford gear box - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 10:37 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
ford gear box
my neighbor has a problem with his tranny its a 99 escort wagon with a 4 cyl. and 5 speed manual tranny the car has 149,000 miles on it
the problem is that he lost 1st,2nd, and reverse if you play with the clutch a little you can work it into those gears but as soon as you let the clutch up the car will die its locked up tight he can use 3rd thru 5th but thats it. im guessing that a gear broke or a synchro Ive never seen a tranny lock up like that before . there is no grinding while shifting.just want to know if im right or if there is a weakness with this tranny that could be the problem.
Old 07-20-2005, 07:51 PM
helrazr3's Avatar
bump
Old 07-20-2005, 08:14 PM
aka Duke of URL
You understand that this is mostly guesswork as it is very difficult to diagnose over the internet.
I would suspect first the linkage being out of adjustment. It sounds like it is in two gears when you release the clutch. That or a bent shift fork. You will need a shop manual to adjust the linkage properly.
Does he bang gears in this thing?
Old 07-21-2005, 06:17 PM
helrazr3's Avatar
thanks, its just the daily family escort wagon he doesnt beat on it at all
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 06:53 AM
Ford 9" gear id. Jared Transmission - Rearend 4 06-07-2004 02:47 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 05:50 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
'56 Gear Box Seon Suspension - Brakes - Steering 2 08-20-2002 08:27 PM
