Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford Guru's - help needed!
Old 08-15-2011, 05:41 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Tilt Wheel? Some issues with the ignition switch or key and tumbler. Ignition switch is bolted to top of the column below the instrument panel. Switch adjustment, bad switch, or key tumbler rack wore out/brock.
