Ford guys 351 Distributor ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2006, 04:14 PM
Richie Z's Avatar
New Member
In looking at the aftermarket distributors for a 351W I see some that fit through 80 some that fit 85-97 and some that don't list any year at all, what gives? Other than the gear material what other differences are there? I'm looking for a ready to run unit for a 84 engine. Are there any blue oval guys out there that know the score? Thanks in advance Richie Z
Old 03-13-2006, 10:32 AM
The only difference I know of is if the cam is a roller or non roller ,which has to do with the distributor gear. hope that helps.
Old 03-13-2006, 10:46 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
There was also 3 different non-compatable ignition systems during those years. Also the W has a unique distributor.
Gear compatability is definitely a factor. Hence some are sold without the gear because there might be a mix/match situation with cams, etc. Builders might prefer a special aftermarket gear material.
Yes, that applies to the Chebbies too.
question for all you ford suspension guys Blag Suspension - Brakes - Steering 7 03-29-2005 11:59 PM
Help from The Ford Guys trees General Rodding Tech 16 03-25-2005 07:45 PM
rod ratio better in a 350 chev or 351 Ford? Dubz Engine 2 03-01-2004 09:10 AM
63 ford pickup 292 to 351 swap crbird Engine 2 01-14-2003 10:42 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
