Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ford help needed
Old 09-10-2012, 01:30 PM
monster76 monster76 is offline
as far as flywheel order the factory flywheel for a 67 289 they should be a 28oz imbalance and the input shaft should be the same 10 spline so you should be able to use a factory clutch as far as engaging the clutch you are probably going to have to use the f150 stuff which i think is hydraulic or maybe you can source all the linkages and make them work on that trans
