ford help needed
hello i have a 1967 289 that i want to mate a 1990 5 speed that was behind a 300 6 what fly wheel do i need and what clutch do i need, wheres the best place to buy the parts, thanks dave
as far as flywheel order the factory flywheel for a 67 289 they should be a 28oz imbalance and the input shaft should be the same 10 spline so you should be able to use a factory clutch as far as engaging the clutch you are probably going to have to use the f150 stuff which i think is hydraulic or maybe you can source all the linkages and make them work on that trans
thank you , thats what i did the flywheel bolts up jest find, but the clutch cover doesent,the three allinment pins on the fly wheel are ok but the bolt holes are off ? any help would be apperishated. thanks Dave
You need the clutch cover that matches to your flywheel..as in if you have the correct 67 flywheel you need a 67 clutch cover..The aftermarket clutch guys can help you with that piece..
Sam |
| All times are GMT -6. The time now is 08:27 AM. |
