Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford inch assemble procedure
Old 09-21-2012, 07:56 AM
V8Square V8Square is offline
Last journal entry: Volkswagen V8 Squareback project.
Reassembly
Originally Posted by OneMoreTime View Post
what is done is to install the 3rd member into the housing and then the axles go in with the backing plates..bearings are pressed on the axles..4bolts hold everything in place..then all tha tis left is to install the brakes and drums and good to go..
Sam
Thanks. So, after I install the third member, I install the axles, with bearings already pressed on. When installing the axles, will the retainer plate, once bolted up to housing, pull the axle/bearing in and seat properly? Also, do you know where I could get an exploded view of the rear end? Tom
