Ford inch assemble procedure - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 03:39 PM
I knows this may sound stupid, but can anyone tell me the step by step process to assemble my 9" Ford rear end? I am new to all of this and need all th help I can get.
Old 09-20-2012, 03:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
https://www.google.com/search?q=rebu...ient=firefox-a
Here are some links to that info..I send mine out as I have a resource that is reasonable and good..Takes a few special tools but is doable at home if you desire..
Sam
Old 09-20-2012, 07:16 PM
Rear end assembly
Sam
Thanks for the link. I already have my third member together. What I need to know is the sequence to reassemble the rear end. How are the axle bearing installed, etc? Tom
Old 09-21-2012, 12:11 AM
Wiki Edits: 3
what is done is to install the 3rd member into the housing and then the axles go in with the backing plates..bearings are pressed on the axles..4bolts hold everything in place..then all tha tis left is to install the brakes and drums and good to go..
Sam
Old 09-21-2012, 06:56 AM
Reassembly
Sam
Thanks. So, after I install the third member, I install the axles, with bearings already pressed on. When installing the axles, will the retainer plate, once bolted up to housing, pull the axle/bearing in and seat properly? Also, do you know where I could get an exploded view of the rear end? Tom
Old 09-21-2012, 10:06 AM
big gear head's Avatar
High Performance Rear Ends
If you are using stock Ford retainer plates then the retainers must go on the axles before the bearings are pressed on. The axles and bearings will fit through the hole in the center of the brake backing plates. The backing plates will be sandwitched between the retainers and the housing ends. The bearings will stick out of the housing ends the same amount as the thickness of the backing plates so that the bearings will be flush with the backing plates when installed. The retainers will hold the bearings and axles in the housing with 4 T bolts and nuts. If you have the standard sealed ball bearings then you will need to install axle seals in the housing ends befpore you put the axles in. If you have the tapered roller bearings then the seals will be on the outer side of the bearings. DO NOT use axle seals in the housing ends if you have the tapered roller bearings.
Old 09-21-2012, 10:39 AM
Rear end assembly
Thanks for all the info. Now, if I just had an exploded wiew of the rear end...
Old 09-21-2012, 11:29 AM
prostreet6t9's Avatar
Differential/Driveline
If you google it... There's a ton of pages.
Ford 8 Inch which drum brakes? (41 ford) nba1341 Suspension - Brakes - Steering 3 04-27-2012 08:11 AM
complete steering wheel assemble tommy evans Suspension - Brakes - Steering 2 01-10-2011 07:45 AM
How to Dis-assemble 9" Ford Rearend fredbaker Transmission - Rearend 3 09-24-2009 10:48 AM
how easy is it to assemble braided steel lines? malibu68 Engine 2 08-11-2006 12:58 AM
9 inch Ford disassemble procedure 38 ford 4 door Transmission - Rearend 2 04-03-2003 10:31 PM
