ford inline sixes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2008, 05:28 PM
ford inline sixes
i have a ford 300 inline six i want to make at least out run Chevy small block i a have a limited supply of money so if anyone has some tips to give me it would be appreciated
Old 05-31-2008, 11:48 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
fordsix.com, inlinersinternational, fordtrucks.com, and a bunch of Mustang forums all have info on the six.
Old 05-31-2008, 11:59 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
First thing is to find some money as everything for one of those has to be built...Once that is sorted out look for a truck block and crank that has the forged steel crank in it as those can handle some serious HP..Have the block cleaned and sonic tested for defects and then have a competent machine shop do the normal race prep on it..decked and line honed and all that sort of thing..Stock rods should be good for anything that you will do on pump gas..have them straightened and shot peened..
Pistons I do not have a clue on those right now..I am sure someone knows though..Heads on the 300 are a bit restrictive for high HP so some of the guys are working using the Chev LS-1 heads to make a head that fits the 300 six..Gotta go see someone like Steve at Eagle Machine though for that kind of work as not too many local shops are equipped or have the expertise to do that..
Cam for that go to Cam Research up in Colorado and have one made to suit and go with roller rockers as the spring pressures in one of those will eat a flat tappet cam in short order..
Induction go with Hilborn stacks or make your own using Ford injectors and a Megasquirt ECU to contorl them..After all of this the headers will be a no-brainer..
Can you DIY a lot of this..sure you can,,just takes determination to get it done..
Moving to engine..
Sam
Old 06-01-2008, 06:09 AM
Wiki Edits: 31
Turbocharger, it's the only way to make power on a budget with a 6cyl. somthing like an HX 35.. Go to www.fordsix.com for help. a few people tunning turbo 300's. Classic Inlines is an excelent source for parts, there even in the middle stages of producing an aluminum cylinder head for the 240-300, they have 1 in production for the 144-250.
Old 06-01-2008, 06:52 AM
I don't think you have realistic goal(s).
It's quite common to make 500+ HP with a sbc, unless you're talking about a 267, then you might have a chance of outrunning one. It sounds as though you're scared of the sbc, wanting to outrun one and all, can I ask why? Has one been chasing you down? You better find some more money or your ford will start spewing ford dust from its bowels. IMHO
Old 06-01-2008, 07:06 AM
I agree with Stroke on this. While it is a good engine, and quite capable of putting out some serious horsepower; it's going to cost a lot of money to do it.
Basically, since this was built as a truck motor, it was never marketed or produced for its performance capabilities. So, there is really not any factory technology (like for some of the high performance 4 bangers out there) to make it a high output piece from the start.
You have to do it from the aftermarket. Do some research. Suppliers listed above have many ways to make HP. Keep in mind the gas of today, and the limits of your pocketbook. Maybe build something relatively mild and efficient; and put it in a Maverick, Falcon, or something real light. It'll run.
Old 06-01-2008, 12:29 PM
thak you helpful pepole
some of you people helped the rest of can kiss my grits because the sbc i meant was stock and i want the punk driving to relize it is p.o.s (no ofense to chevy lovers)
Old 06-01-2008, 04:39 PM
Getting power out of a six is very doable but comparatively expensive. Here's a URL to get you started:
http://www.cliffordperformance.net/M...gory_Code=F300
Basically the 6 responds to the same things as an 8, better intake, larger carb, more cam, more compression, headers and duals all contribute to improving power.
Keep in mind that the large 6s use a lot of V8 parts; pistons, rods, lifters, valves and valve springs have degrees of interchangeability.
The intake and exhaust system on the big Ford 6 can not only be replaced with over the counter parts, though expensive compared to an SBC or a SBF for that matter. However, with some shop skills these engines lend themselves to the fabrication of manifolds from mild steel tube at home or in a shop class at school.
The usual things will have an effect, headers into duals would be a decent and less expensive place to start. More compression can be had by milling the head. Certainly replacing the 1 barrel and its intake is desirable. A 4 barrel Clifford would be nice, but you can fabricate one from exhaust tubing, or even modify the existing intake by making adapters than can be clamped, epoxied, or brazed to the cast intake to use 3 to 6, 1 barrel carbs. Or modify the intake to take 1, 2, or 3, 2 barrel carbs.
The cam needs replacing for any kind of performance work, unfortunately the only solutions here are new or re-griding the shaft you have.
It always takes money, but with an inline 6 a little cleverness and some fabricating abilities can go a long ways.
Bogie
Old 06-01-2008, 05:25 PM
Wiki Edits: 31
a cheap option instead of headders is the EFI manifolds, there 2 peices and flow better than the old single peice manifold.. then you can port them out a little.
Ford Inline 6 4.9L with only 145 hp? GnrYmr Engine 13 12-02-2009 11:06 AM
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 09:09 PM
