Ford king pin spindles
I was wondering if anybody knows the geometry of 67 ford truck spindles (1/2 ton) and if they could be used on a drop tube axle? If it is possible I understand I would have to build the axle myself and that isn't a problem. the reason I ask is I have a doner truck with good motor and was going to scavange all parts i could for a T bucket build.
A beam axle is flexible whereas a tube (esecially chromed) may be damaged. |
Bob |
king pin inclination
Thanks for the info. Does anyboby know the standard king pin inclination on spindles typically used on drop tube axles. Is the inclination measured in degrees between the stub and the king pin bore?
Bob |
spindles
Thanks again for the info. Hopefully I will be able to jerk those old spindles out tomorroe and then with them in hand will be able to compare them with a vintage set. I have a friend whoes father in law has a t bucket he built in the late 70's. sorry to take so long to get back to you but i use comp. in free time at work on 3rd shift.
| Ford vs Chevy question | savman1 | Engine | 31 | 10-14-2008 07:13 PM |
| Explorer Disc Bbrakes on a 9" Ford Rear End | Mustangsaly | Suspension - Brakes - Steering | 2 | 10-31-2005 04:18 PM |
| Wanna Talk Cars "Fords" | 66Falcon | Hotrodders' Lounge | 17 | 10-01-2005 05:29 AM |
| T-5 transmission codes needed | xntrik | Transmission - Rearend | 4 | 09-06-2005 09:09 PM |
| Will ford 14" rallys fit granada spindles | FAIRLANE DUDE | Suspension - Brakes - Steering | 1 | 10-07-2003 09:23 PM |
