Ford knobs on a Delco GM radio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 06:57 AM
staleg's Avatar
Last journal entry: Hand brake
I have a GM Delco stereo FM car radio from around 1980, but the knobs are missing.
I see lots of nice radio knobs for sale on Ebay all the time
Will knobs from a 70's Ford radio fit?
Yea, it's a funny question, I know....
Old 08-04-2010, 07:11 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Let's put this in General Rodding Tech too.
Dan
Old 08-04-2010, 08:46 AM
I'm not sure about what fits, but most of them seemed to be fairly similar in design.
There is usually a larger diameter chrome ring closer to the radio, behind the knob. On one side it is used to adjust tone (bass-treble) on the other to fade from front to back speakers or from left to right. Both of those rings usually have a notch in them to provide a center position. The knobs are then pushed on to the shaft after the rings. One knob is usually just a push-on press fit, while the other may have a flat piece (to match the shaft) that gives it more leverage to turn the radio dial.
Bruce
Old 08-04-2010, 08:51 AM
You might try looking at these items. They are for a Corvette, but its probably the same radio.
http://www.zip-corvette.com/GroupDetails/SubGroupResults.aspx?gid={d80c4332-8e02-4b8b-99f7-4a34142faf97}&SearchType=_GROUP_SEARCH&GroupName=R adio+Face+Kits+%26+Knobs&
Bruce
Old 08-04-2010, 09:48 AM
ksg ksg is offline
Delco radio knobs
Hello Staleg.
I have a radio "salvage yard" from about that time frame.
Post a photo of your radio, and I will check inventory.
KSG
Old 08-05-2010, 12:27 AM
staleg's Avatar
Hi ksg. That's interesting!
My radio need slotted centre hole on both inner knobs. Correct me if I'm wrong, but I think the right side inner knob on mono radios is only a dummy?
My plan is to use the same style knobs on headlight, lighter and fan switch as the outer knobs on the radio.
I like very much the Chevy '68 model knobs, when the inner knobs are chromed. But they might be too big and bulky on a small hot rod dash with the typical small after market instruments?
My second choice IF those are smaller, is to polish up the front on the GM brushed aluminium ones from around 1977. That's maybe the knobs that were intended for my radio in the first place?
Here's the radio:
I'll might do something with that black house on it.
I'm also very interested if similar centre push knobs have been made in chrome finish?
1968 Chevy knobs:
1978 Chevy knobs:
Old 08-05-2010, 08:03 AM
ksg ksg is offline
Radio knobs
Anything can be made into a radio knob!
Plastic, wood, stainless steel, anything.
Matching knobs with the other dash knobs is the ideal plan.
Pick out the size, shape, color, material, etc. for the perfect dash, and radio knobs are easy. The trick is in the insert that goes between the knob and the radio shaft. Build the knob, insert, and away you go.
KSG
Old 08-07-2010, 03:38 AM
staleg's Avatar
I know. But I want is to use something that already exist.
(The hot rod project has taken me close to 10 years already...)
The number of different radio knobs are enormous, some of the them are quite some pieces of art. I just want to get some that fits and that also can be used on my universal fan switch and a headlight switch.
GM radio theft lock (hey-doc help) joseph brown Electrical 4 04-24-2006 07:40 PM
ford drive shaft same as gm 225buick Engine 3 05-20-2003 09:29 AM
36 Ford Banjo wheel to a late GM column Django Interior 8 01-07-2003 07:52 AM
Old Ford Radio ZigZag Interior 2 01-03-2003 05:39 PM
cigarrette lighter and radio for 1939 ford deluxe 1939FordDeluxe Interior 1 11-20-2002 02:02 PM
