Ford M/C - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2011, 01:23 PM
Ford M/C
Changing my M/C from a GM to a Ford. Can some one confirm the larger bowl on the Ford M/C is for the rear brakes?
Old 06-24-2011, 01:31 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
That is incorrect, the large reservoir is for the extra fluid needed for the front discs.
Rich
Old 06-24-2011, 02:21 PM
Thanks, that is what I thought, maybe the guy who told me that assumed it was drum brakes all around. I have converted the front to disc so i will go with your information. The M/C is from, I think, a mid 80 fairmont. I switched because I wanted to upgrade to a dual master and the fittings had to be inboard because od space limitations .
Mike
Old 06-24-2011, 03:06 PM
Mike
When you changed over to discs did you add a proportioning valve or combination valve? it is needed to have the front & rear brakes work in concert, that is the rear brakes need to be activated before the discs. Why because the pads are in contact with the rotor all the time, the rear shoes are away from the drums & need the extra time to contact the drums.
Rich
Old 06-24-2011, 03:29 PM
Installing a prop. valve in the morning. I have replace every inch of brake line, rubber hoses and rear wheel cylinders. The front disc are all new. as well as the MC. Can not wait to try my new power bleeder.
Old 06-24-2011, 03:41 PM
Good going Mike & the very best of luck to you.
Take care & keep safe
Rich
1934 Ford transmission with1948 Ford truck engine clutch questions ppetrano Transmission - Rearend 1 05-20-2011 11:02 AM
1998 Ford F-150/1957 Ford Delivery Sedan Dennis Anderson Introduce Yourself 1 12-29-2006 06:10 PM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 08:14 PM
pros vs cons puttung ford motor in 38 ford 38harry Engine 5 08-30-2004 05:28 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
