Ford-a-matic - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 06:02 PM
Ford-a-matic
Tranny, has more than one leak. I'm open to any and all suggestions on trying to stop or elimainate most.
Old 04-05-2013, 08:14 PM
vinniekq2's Avatar
take it apart and fix it
Old 04-07-2013, 10:22 AM
Wiki Edits: 85
There are not many places any transmission can leak from. Basically the pan, the output seal, the tail housing gasket, the front pump, the servo covers, and the levers. Except for the front pump, most of them most of the time can be fixed with the transmission still in the rig.
Unless you have a front pump leaking, just fix the leaks one at a time until you have no more leaks. If the front pump is leaking, either rebuild the transmission since you will already have it out, or at least replace all of the external gaskets and seals.
Old 04-09-2013, 03:25 PM
Thanks for the info mmerlinn, pepper
Old 04-11-2013, 02:27 AM
JeffB's Avatar
You might want to check out this site also: Ford Transmission Forum
Three speed Ford o Matic to C4 highwaystar Transmission - Rearend 1 01-06-2013 11:06 AM
Ford Cruise-o-matic 65fourdoor Transmission - Rearend 6 03-01-2009 01:02 AM
Ford Cruise-o-matic Billy Boy Transmission - Rearend 15 12-02-2004 08:44 AM
ford cruise o matic 65galaxie500 Transmission - Rearend 5 11-17-2002 09:54 AM
ford o matic yblockv8 Transmission - Rearend 1 09-06-2002 08:01 PM
