Ford Model A front bumper? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 03:24 PM
31ROC's Avatar
Have a '31 Ford hot rod. I have seen many pictures of these cars with a chrome "bar" between the frame rails used as a front bumper, but cannot find them to purchase?
Ideally, the one I really want is a "V" shape chrome bar, and it had built in parking lights.....
Old 04-29-2012, 03:36 PM
35terraplane's Avatar
31 Ford
What your looking at is a 32 Ford spreader bar, they don't make them for 31 Fords'. The ones you have seen are either 31 Fords that are on a 32 frame, or some one has made the bar fit a 31 frame. Most guys building a Model "A" would use a 32 frame but not all. You can get a vee shaped one and cut it to fit but your best bet would make your own, or have one made then you can have it chromed or you can paint it.
Bob
Old 04-29-2012, 03:48 PM
31ROC's Avatar
so I cant buy this V-shaped bar already chrome?
Old 04-29-2012, 04:01 PM
http://www.socalsac.com/stepped-boxe...-spreader-bars
Old 04-29-2012, 04:08 PM
Speader bar
Brian was nice enough to look one up for you, looks like you can get a straight one but you have to make the brackets it looks like to me. Maybe if you look at some of the other sites some one has some.
Bob
Old 04-29-2012, 04:10 PM
http://www.rodtiques.com/catalog.php...t_Spreader_Bar.
Google image -- Model A spreader bar frame
http://www.google.com/search?hl=en&r...Ms_ViAKq-5STAQ
Old 04-29-2012, 04:44 PM
spreader bar
Looks to me like you can get them with turn signals and with, or without flanges to mount, but only straight not in a vee, they are for 32's.
Old 04-29-2012, 07:02 PM
Irelands child's Avatar
The OP was looking for a 'V' shaped spreader bar - which I have never seen for an A.
Also - to the OP - if you are running the car with a grill splash shield, you will need to modify it to clear around that bar. I had obtained some brushed SS to make one for mine, but decided I had too much time and painting to start over so just ended up with nerfs instead and might be something for you to consider - though it doesn't help with lights.
The spreader bolts where you see the 2 small bolts (there are large hex shaped bumper bolts under the splash shield)
Old 04-30-2012, 01:08 PM
31ROC's Avatar
thanks for everyone's help....did find numerous straight bars, no "V" shaped yet....its a lot easier when you look for the "correct part"! I was searching "bumpers" instead of "spreader bars"....appreciate the input.
front straight axle on 32 ford model b truck BonnevilleBrat Suspension - Brakes - Steering 6 01-28-2009 11:00 PM
48 ford truck w/T model front axle tripp68 Suspension - Brakes - Steering 13 01-02-2008 06:36 PM
No drilling in my front bumper...please! gwhpnut Body - Exterior 2 08-09-2006 02:43 PM
front bumper of a 73 Mustang flyfisher Body - Exterior 11 01-13-2005 03:11 PM
Front Bumper Removal!!! zipfactor Body - Exterior 2 07-12-2004 01:41 PM
