Ford Motor
Hey all new to this forum, but i have a Ford motor in a boat I bought. The guy I had bought it from told me it was a Ford 427, well I know its not that now after ordering a new Distributor and it not fitting! Summit racing helped me figure it down to a 351 cleavland, 351 modified, 400 modified. I have gotten some numbers off of the intake manifold but it didnt seem to help. I tried to locate the block # but can't find it? Any help with any and all info on this would be appreciatedBilly |
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow. 351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal. 429/460 385 series: 7 bolts in rectangular valve cover 352/360/390/427/428 FE series: Intake goes under valve covers. -There are other indicators but these are enough to distinguish engine families. There is no way to tell a 351M from a 400 externally. The most accurate way is to remove the oil pan and look at the crank. 400 Crankshaft ID. http://www.tmeyerinc.com/400crankshaftid.html |
351C/M/400 (335-series)fuel pump bolts are vertical, horizontal on everything else. 335/385 series all had canted valves. FE intakes: If you get a hernia lifting the cast-iron intake manifold, you know for sure it's an FE. Nitro_baller said 351C has screw-in frost plugs. I don't think so. I'm pretty sure that Boss 302 was the only one that had screw-ins. Actually, here is a link that I had in my "Favorites":Ford Engines It has all kinds of indentifying information. |
well so far i have narrowed it down, there is no id tag below the coil> that is gone. all i need now is to figure out is it a 351c/m/400m? how do i do this?
thanks again all Billy |
Regardless, the same distributor fits 351C, 351M, 400, 429 and 460 motors.
Cheers! John |
imo, i think you ought to see about getting some purchase price back..... even if it's a 351C, it still isn't worth as much as a 427. I hope you didn't pay 427 money for it.
| Early Ford Wire Wheel Tech | wheelkid | General Rodding Tech | 1 | 06-02-2006 12:15 AM |
| what ford motor cid do I have | chasmueller | Engine | 2 | 06-01-2006 06:20 AM |
| 514 CU.IN FORD CRATE MOTOR? | hotrodders4christ | Engine | 2 | 05-02-2006 08:52 AM |
| Ford motor change question | Churchman | Engine | 3 | 05-27-2005 09:51 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
