Ford nine inch axle bearing number - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2011, 01:15 PM
Nothings ever easy....I have to replace a rear axle bearing and have no clew what yr this nine inch comes out of...its in my streetrod....the number on the side of the axle bearing is w508er or wso8er....is there a way I can match this up with something....thanks..craig....who makes these bearings...maybe I could contact them?
Old 07-13-2011, 03:39 PM
prostreet6t9's Avatar
Differential/Driveline
Call Dutchman or Moser.. They will have those Brgs.
Old 07-13-2011, 03:50 PM
Thankyou
We figured out this is a Moser 9inch rearend...Summit Racing handles the bearings and seals..just make sure the right axle size is ordered...thanks for your help..craig
Old 07-13-2011, 06:34 PM
Most any parts place will have them just take one in and tell the counter
person that it's a 9" ford and you don't cure what year as long it is the same size.I don't think they used but two sizes. At lest I DON'T remember but two. good luck.
OLDROD
Old 07-13-2011, 06:42 PM
I think the problem here
is that moser engineering uses a different size axle from a stock 9 inch rear end?....the id of the bearing has to fit the moeser axle...we tried a stock 9 inch bearing today and it just slid on the axle...not good..the part number on my old bearing is w508er which matches up with moesers...
Old 07-13-2011, 07:06 PM
I don't know about moser but if IT were me I would go to the advance store with the bearing and see if they could match it. Just me I guess but I like to see what I am getting when possible.
OLDROD
Old 07-13-2011, 09:36 PM
Here's some 9" axle sizes and bearing numbers that I use...
axle dia 1.532" / Timkin Brg 514003
axle dia 1.564" / BCA RW 508-ER1562
Old 07-14-2011, 12:48 AM
SSedan64's Avatar
Hope it's not the leaky made in China bearings that Moser is now using. They start leaking quickly if synthetic Gear oil is used.
Old 07-14-2011, 02:46 PM
Ok...Job Done
I got my drivers side axle bearing replaced today...I ordered a moser 9508B with a 3.150 od and a 1.531 id from summit racing for 64.95(comes in pairs with retainer) plus shipping...you need to be alittle careful reading part numbers on mosers website...it gets alittle misleading...the important thing to know when replacing moser bearings is that its a nine inch rearend...then you need to know the od and id and you can order from them or someone like summit...this worked out good for me ..we were able to overnight the part and back in business the next day...craig..on to my next project..
ford 9 inch axle spline count torquemonster Transmission - Rearend 15 06-09-2011 08:51 PM
Ford 9 inch outer axle Bearings 55effie Transmission - Rearend 5 06-28-2010 12:31 AM
Ford 9 inch Axle Bearings DRKSIDE Transmission - Rearend 3 06-14-2010 06:07 AM
Ford 8 inch axle end play junkyardjeff Transmission - Rearend 12 04-24-2010 05:49 AM
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 06:30 PM
