Ford Nine Inch - Pinion Retainer Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2009, 09:20 AM
I've got a slow leak between the pinion retainer and the center section case.
I understand I need to remove the five bolts holding the retainer on, my question is can I remove the yoke and pull just the retainer off to get to the o-ring or do I have to leave the yoke assembled and remove the whole assembly including the pinion? I have an exploded view of the 9", but can't tell which way to go.
I've got a solid spacer if that is any help. The center section was rebuilt about 6 months ago, I broke in the new gears and it has sat unused for the last 4 months. The guy who rebuilt it would fix it for me, but his turn around time is too long.
Some guidance would be greatly appreciated. Thanks
Old 04-09-2009, 09:26 AM
prostreet6t9's Avatar
Differential/Driveline
You can leave the yoke on and pull it out as a assembly.
Old 04-09-2009, 09:30 AM
Just make sure and keep track of the shim or shim's.After you change the O-ring,you can put a little sealer on the O-ring to help with any imperfections in the case.
Old 04-09-2009, 09:42 AM
Thanks for the quick reply.
Just to make sure I don't screw anything up:
1. I'll put the yoke on, torque to spec.
2. Pull the 5 retainer bolts
3. Pull out the assembly while twisting the yoke to unseat the pinion (do I have to watch for anything falling off or misaligning?)
4. Fix the O-ring (can I use RTV for this, the seal is new)
5. Drop the assembly back in
6. Torque 5 retainer bolts to spec
7. All done, drink a beer
Thanks, I obviously haven't done much work with center sections, so I appreciate the help.
(Didn't see your other post - THANKS!)
Old 04-09-2009, 10:00 AM
Beer? I'm only 40 minutes away maybe I need to give you a hand with that!
Old 04-09-2009, 10:04 AM
Ha! 80 minutes for A beer is quite a long time... Might have to make it two. Where abouts do you live?
Old 04-09-2009, 10:05 AM
I would pull the assembly out first:
Remove yoke.
Install your solid spacer. It's easier to set the preload with the pinion out.
Watch for your pinion shim or shims so you can install the same one's back,so your pinion depth stay's the same.
RTV would be fine,Just wipe the excess off so it look's nice.
Old 04-09-2009, 10:09 AM
Salem,Yea 80 minutes might be a 2 or 3 beer ordeal! If you run into any problems I will be up the next weekend for the gun show.
Old 04-09-2009, 10:13 AM
Remove yoke.
Damn, now you lost me... I thought that because I have the solid spacer, I don't have to worry about preload (where with a crush sleeve i would have to worry about preload)...
Old 04-09-2009, 10:15 AM
Sorry,I thought you where removing the crush sleeve and Installing the solid space.My bad!
Just remove the assemby and leave the yoke on.
Old 04-09-2009, 10:17 AM
No need to remove the yoke for what your doing!
Old 04-09-2009, 10:24 AM
Ok sweet, I thought my easy little repair was going to get more difficult. Sounds like I'm up to the task for this...
Thanks for the help, I'll buy ya a beer if we ever bump into each other. I'll be driving a medium green metallic '67 Mustang coupe with 17" Hopsters and 315 BFG Drag Radials outback...
Old 04-09-2009, 10:26 AM
Remove the 5 pinion support bolt's.
remove assemby.
Remove old o-ring
Clean the oil off pinion support and case
Install new o-ring with sealer
Install assembly
Clean any excess sealer
Done!
Old 04-09-2009, 10:32 AM
Ah man! If I'd known I was helping a Ford guy I would've told ya wrong! Kidding! Sounds Like a nice car! Your Welcome! If ya have any problems let me know and we will get it figured out.
Old 04-09-2009, 10:37 AM
Why do you think i waited to tell you I'm a Ford guy... You pesky Chevy guys are all the same... Kidding
Thanks again.
Ford 9 Inch pinion yoke length?? baddbob Transmission - Rearend 15 05-31-2007 11:40 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
4 inch drop axle with Maval rack and pinion Dirty Steve Suspension - Brakes - Steering 3 05-16-2006 11:56 AM
which 9 inch Ford to use dbell Transmission - Rearend 3 02-28-2006 07:17 PM
Ford 9 inch rear sodas38 Transmission - Rearend 0 05-07-2004 01:38 PM
