ford? nine " rear tag info - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2006, 08:02 PM
Just bought a ford 9" rear today the tag has the following on it WGB-A8 6MC
2 50 9 461A
I know that the WGB-A8 is a .250 rear but don't know What its out of or if it's a pos. It had disk brakes and coil springs. will take all help.
Thanks
Old 05-01-2006, 10:29 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's one site that will give u tons of info on 9" ford rearends...joe
Old 05-02-2006, 10:27 PM
powerrodsmike's Avatar
Wiki Edits: 161
That is an awesome site. Lots of useful spotters info there. It pays to look in the knowledge base.
mikey
BE different....ACT normal.
82-92 camaro posi rear end info NoEgoMan100 Transmission - Rearend 4 10-21-2005 02:22 PM
Ford 5.0, 302, 351W Performance Info xntrik Engine 10 09-06-2005 11:01 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
