Ford pinto - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2003, 12:26 PM
Post Ford pinto
I tore down a 289 HO for my pinto the motor sat for 20 years before I got it.It supposedly only had 4000 miles on the engine when parked.I pulled heads intake oil pan,everything looked brand new so I put it back together and just replaced the gaskets, distributor and plugs.The reason for tearing it down in the first place was because a piece of dis. gear broke off and motor locked up, but it didnt scar anything.when I try to start it,it just backfires out the exhaust,my timing should be right but could it be stuck valves,if so whats a quick fix if any.helps greatly appreciated because if my girlfriend has her baby before its started the car goes down the road ,babys are expensive.
Old 01-06-2003, 03:11 PM
aka Duke of URL
Arrow
How did the piece of gear lock the motor? Where did it lodge?
What was the oil pressure when you pre-lubed it?
Sounds like you need to start with either a compression or leak down test.
