Ford question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2007, 07:28 PM
anthonyc's Avatar
Ford question
My friend has a 69 Torino with a 351 Windsor 2 bbl. The car runs really well idles good and smooth and no miss but just today he found that when he is waiting at a light the car begins to buck and eventually stall but starts right back up and continues to run fine but then another light holding the brake it happens again. I checked for vacuum leaks and found none at least in the obvious places. Could the brake check valve on the brake booster cause this or am I missing something. He just just put in a set of plugs about a month ago is there some ford specific thing to look for? Please help me out here. Thanks.
Old 03-25-2007, 07:43 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
vacume leak
sounds like power brake booster dia. leaks.if not carb idle circuit poss.
Old 03-25-2007, 07:46 PM
aka Duke of URL
...when he is waiting at a light the car begins to buck and eventually stall but starts right back up and continues to run fine but then another light holding the brake it happens again...
Try blocking the vacuum source for the booster and try it again (in the driveway).
Old 03-26-2007, 04:32 PM
anthonyc's Avatar
Thanks fellas Im going to give it a try tonight, let you know what happens.
Old 03-26-2007, 08:37 PM
anthonyc's Avatar
Ok guys we worked on it tonight . I replaced the check valve. But I think the brake booster is bad . The pedal goes to the floor when the car is running and stays there after turning the car off the pedal comes back up am I correct in thinking it is the booster ? I dont think its the master becasuse it dosent come back up. Also when I was looking for the booster online I found two one says with midland booster what is that? Also why does the clamp band matter (it lists with and without that too) I am sorry for all the questions but I am not too familiar with Fords.
Old 03-27-2007, 01:31 AM
aka Duke of URL
There were two vendors for the booster. They are trying to identify which one you have.
Old 03-27-2007, 07:20 PM
anthonyc's Avatar
does the Clamp band Identify which one ? Is that what midland means,the supplier. The car does have factory front disks.
Old 03-27-2007, 11:37 PM
aka Duke of URL
Originally Posted by anthonyc
...does the Clamp band Identify which one ? Is that what midland means,the supplier. The car does have factory front disks.
Yes, just supply the requested information to the parts dude.
Old 03-28-2007, 07:31 AM
anthonyc's Avatar
Ok thanks I am going to work on it sunday I will let you know what happens.
Old 04-01-2007, 01:46 PM
anthonyc's Avatar
I have the new booster on the way it should be here on Mon or Tues. my next ques is how do you bleed the master on that car. There is a little bleeder screw right on the master do you open that with it installed on the car and bleed it with the pedal? Or do you put it in the vice and bleed it the normal way then quickly bring it over to the car and install. Thanks .
Old 04-01-2007, 02:19 PM
m/c
couple tip- m/c will nearly bleed itself,you may have to stroke a few times.Be sure to measure depth m/c hole.adjust rod end to make same.Install- then 1 at time bleed m/c connections.most of the time I don't have to bleed w/cyls
Old 04-01-2007, 05:52 PM
aka Duke of URL
There is a fairly cheap kit available that allows you to bleed the MC either on the bench or car. It has two rubber hoses that shoot the fluid back into the reservoir.
Old 04-01-2007, 06:49 PM
anthonyc's Avatar
Thanks for the response guys . What I dont understand is what is that bleeder screw on the master it self for?
Old 04-01-2007, 10:12 PM
aka Duke of URL
You can bleed from there (I would still blench bleed). Haven't seen one of those in quite awhile.
Old 04-02-2007, 12:42 PM
anthonyc's Avatar
Great thanks for the help . I will bench bleed, working on it on Tues.
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
ford truck question william r plise Body - Exterior 3 05-11-2006 05:38 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
34 Ford fuel tank question 302 Z28 General Rodding Tech 1 02-01-2004 04:55 PM
I have a question about ford f150 Thuggishruggish3000 General Rodding Tech 2 12-12-2003 06:45 AM
