Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 09-26-2007, 06:12 PM
Ed Farrell Ed Farrell is offline
New Member
Ford rack and pinion steering on my street rod
Does anyone know which fittings are [presure/return] and where can I get them. I went to Pick-a-part and couldn't find a Ford product with my steering gear. I bought five fittings but none were usable in my application. Some are inverted flare and some are a fitting with a plastic washer. I have to make my own lines as it was necessary to put the P/S pump on the righthand side of the engine. ['36 Hupmobile]. Thanks, Ed Farrell
Old 09-28-2007, 10:10 PM
banditosmith banditosmith is offline
I had to buy a hose to fit rack cut metal end off then bought hose to fit pump ,cut metal end off then had local parts make a hose with ferrule's and put metal ends on it. Yes a 150.00 hose but it fit and dose'nt leak.
Old 10-07-2007, 07:38 PM
oldguy829's Avatar
oldguy829 oldguy829 is offline
 oldguy829's barnstar
Wiki Edits: 85
ford rack and pinion
Our local hot rod shop has adapters tha t change most every fitting to a flare fitting, then they make you a hose (steel braided) with 2 flare ends. About 50 bucks with the adapters. Seemed like a pretty common practice.
Old 10-08-2007, 11:12 AM
I thought the something about 200.00 of fittings that leaked like a sieve.Thats why I had to go the hose route.YES there has to be better answers but the hose was only one that worked.I even tryed people that do it and sell it no help. I solved my problem took 8 weeks of spare time and no car but im happy now.I hope someone has a better answer to save next sidekick a headache and frustration.
Old 10-08-2007, 07:25 PM
New Member
re: Ford rack and pinion steering on my street rod
Thanks to all you respondents as I finally got enough fittings and hose and finished the project. Cost, about $80!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Ford rack and pinion steering on my street rod"
Rack & Pinion Steering Rick Dolinar Suspension - Brakes - Steering 2 07-02-2007 06:19 AM
power steering and a rack on a 50 ford 1lowryd Suspension - Brakes - Steering 1 03-05-2007 03:52 PM
MAVAL Rack and Pinion Cross steering 37ford4dr Suspension - Brakes - Steering 10 12-11-2005 04:48 PM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 09:15 AM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 06:56 PM
