Ford Ranger 8.8" Rear Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2003, 04:12 PM
nightrain_rod's Avatar
Blue Oval Finatic
I was wondering..When I decide to do my V8 Conversion with a Ranger and I get my 8.8" rear end from the yard..How can I get disc brakes on the rear without buying a kit?If I can find a Mustang or something with the same rear end with discs,can I just take the setup off that rear and put it on mine?I plan on using a 1984-1986 Ranger,so I doubt front brakes are going to be on there either.Any ideas on that?Any help is appreciated.I'm trying to get out of this the cheapest way that I can,(i.e. Buying an expensive disc brake conversion kit),you know .
Jacob Middleton
Old 06-23-2003, 05:48 PM
aka Duke of URL
Consider a rear asm. from an Explorer. They are 8.8" and later ones come with discs.
Refer to -this article- for measurements, etc. The MUSTANG rear (SN-95) with discs will be set up for coil springs where this will be leaf.
