ford ranger engine swap
i have a 88 ford ranger with a shot 4 banger in it and i have a chevy 350 and trans sitting in my shed having a wild hair and thinking of dropping the 350 in the ranger where can i find all the info i need to pull this off, has anybody down this? thanks
ranger chevy swap
I havent personally done this swap but have seen a couple locally. The chevy fits much better than the 302 ford. Those ford oil pans are a real PITA when it comes to front crossmember clearance. the chevy is a better engine anyway
re. chevy ranger
if i can get pics on those motor mounts i can fab some, shouldnt be to hard to do. ill be looking foward to this prodject come next spring sine its only 11deg. outside now here in kansas. if there is any info on what and how, will be greatly welcomed, thanks everybody.
fits better????
a 302 and 350 are both 22" across the valve covers If the 350 has a short water pump it is approx 2" shorter than a 302, (long pump it is longer than a 302), measuring from the rear block face measure from the intake rear (350 dist clearance) it is 1/2" shorter with a short pump either fits with about the same amount of aggrevation at 575 lbs., the 350 =70/30 weight distribution ? Last edited by red65mustang; 12-07-2005 at 11:01 AM. |
You might want to take into consideration that the Ford has a front mount distributor and the Chevy is in the rear, which is nice and close to the firewall. The Ford also is about 100 pound lighter than the Chevy, but you can lose some fat from that Chevy by bolting on aluminum engine parts.
| Wanna Talk Cars "Fords" | 66Falcon | Hotrodders' Lounge | 17 | 10-01-2005 05:29 AM |
| Engine Swap - 64 Galaxie | Billy Boy | Engine | 5 | 07-21-2005 02:49 PM |
| engine swap on 51 Ford F-3 | rostocker | Engine | 6 | 03-25-2005 01:09 PM |
| 454 engine swap | joes stude | Engine | 1 | 07-17-2003 08:12 AM |
| 55 ford engine swap help | can55ford | Engine | 1 | 11-23-2002 09:33 PM |
