Ford Ranger Hydraulic Clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2003, 06:52 AM
I am trying to set up a hydraulic clutch for my T-5 transmission behind a 302 with a heavy duty Mustang clutch.
I understand Ford Rangers have a hydraulic clutch. I would like to know which years and engine / transmission combinations have this feature.
Thank you for your assistance.
Charlie Vaselaar
AH 5017
Houston, TX
Old 10-09-2003, 08:34 AM
302 Z28's Avatar
My Son has a 94 Ford Ranger with the 4 cylinder engine, 5 speed standard, and the clutch is hydraulic.
Vince
Old 10-09-2003, 04:46 PM
roys63's Avatar
All the rangers, bronco lls have Hydraulic clutches since the first years built.
Old 10-09-2003, 07:27 PM
4 Jaw Chuck's Avatar
Early models had a slave cylinder that was remotely mounted on the bellhousing and the later models (after 85) had a hydraulic sleeve that went over the pilot shaft, this type requires trans removal to install. The early slaves were plastic.
— Han Solo
