Ford Ranger seat back adjuster - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:46 AM
Wiki Edits: 31
I just bought a '98 Ford Ranger extended cab, with the bucket seats from the local Ford dealer. I noticed the passanger seat back adjuster handle is broke and asked the dealer to fix it, as it makes entering the rear back jump seat impossible.. he can't figure out how it comes out, because someone snapped the whole shaft off almost flush with the outside of the seat, instead of just breaking the handle. so it has to come apart enough to at least replace that shaft..
anyone know what has to be done to fix this? dealer may just swap a set of '98 Explorer buckets in it and call it good, but if he doesn't have a good set. then he's going to fix it. he has a '98 standard cab Ranger in his parts lot that could probably lend the correct parts
Re-padding an old car seat. DanTwoLakes Interior 9 09-23-2008 06:52 AM
Ford Ranger manual steering box ? AC/DC Suspension - Brakes - Steering 12 08-12-2006 06:41 AM
36 Ford back seat 36Tudor Interior 11 06-13-2006 04:58 PM
ford F-100 back spacing? joie383 Hotrodding Basics 1 01-13-2006 12:15 PM
Don is going back to Ford parts 66GMC Off-Topic 0 10-05-2005 11:32 AM
