Ford Ranger starting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2005, 07:30 PM
Friend of mine has a 93? ford ranger, 2.3 4 cylinder/5 speed, 2wd. Recently it began not starting unless jumped. Well I loaned him my battery and it ran for a while, then it started doing it again. He said it does the same thing, except now sometimes it will start if you leave the headlights on for a while? and if you throw a charger to it for a bit. Also, if turned to accesory, the lights on the radio will flash. I haven't looked at the thing yet, but that headlight thing throws me for a loop. Any ideas?? I personally suspect that the alternator is dead, but I dont know yet.
68
Old 07-30-2005, 05:03 AM
poncho62's Avatar
Wiki Edits: 5
Check your ground cables, and clean both ends up good.....sounds like it's not grounding well enough.
Old 07-30-2005, 03:02 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Could be an alternator.It is holding a surface charge and when you turn on the lights it pulls it back down.Take the alternaotr and have it tested,bet it is bad.
Old 07-30-2005, 09:16 PM
Thanks guys
68
Old 08-02-2005, 03:14 PM
docvette's Avatar
Wiki Edits: 12
links
Doc here,
Check for a loose Fusible link on the start/charge line.
Doc
How To Wire Up A 302 Ford Ranger izzymiddleton Electrical 3 02-24-2016 03:50 PM
starting problem lori-due Electrical 8 09-10-2004 05:23 PM
Cavalier Starting Problem...help about to light car on fire oldschoolrods Electrical 1 08-05-2004 09:46 PM
problem with ford transmission ,please help mikeweyman Transmission - Rearend 2 05-22-2003 10:58 AM
How do I install dual side pipes on on 97' Ford Ranger? John Rose Engine 2 01-15-2003 05:38 AM
