ford ranger suspension? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2009, 06:55 PM
Last journal entry: Motor build up 2
Hey im rebuilding a ford pickup and i wanted to know if it would be possible to put a ford ranger suspension in my classic ford frame? I know i could go and get one of the fancy ifs systems but i dont have that kind of money and rangers are easy to find around here and thought if i could get a cheap one that would save some money.
Old 08-23-2009, 09:19 AM
Wiki Edits: 27
ford pu
I have seen the ford aero star mini van suspensions, disc, rack steering etc. on one big crosmember. . you would need to fab upper A arm brackets you should be able to find info on the classic pickup web sites they fit under the fenders cost should be about the same as a ranger . I think the aero had bigger brakes.
Old 08-23-2009, 05:32 PM
The newer light duty 2wd rangers may work. It's a coil spring, upper/lower control arm suspension with a rack and pinion , not the twin I beam set up seen on the older models. The heavier 2wd suspension have upper/lower arms but a torsion bar set up and also has larger brakes.
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 11:25 AM
Ford Ranger manual steering box ? AC/DC Suspension - Brakes - Steering 12 08-12-2006 06:41 AM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
S-15 Jimmy suspension under 40 ford pkup? streetrodder31 Suspension - Brakes - Steering 2 08-28-2005 04:06 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
