Ford Ranger V8 Conversion Transmission Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2003, 04:35 PM
nightrain_rod's Avatar
Blue Oval Finatic
On this conversion with a 302 and a C4,do I have to use those expensive adapters for the transmission?I think that those are only manditory if you don't want to tackle any driveshaft mods.Is this the case?
Jacob Middleton
Old 06-24-2003, 04:58 PM
mustang66maniac's Avatar
Ford Freak
what expensive adapters?
Old 06-24-2003, 06:05 PM
BOBCRMAN@aol.com's Avatar
Got an 88 ranger shortbed, 302-C4 bolted in, flat stock for engine mount adapter, had to cut heater box for valve cover clearance, Hedman shortie headers, everything else was bolt on or weld up, simple conversion, what adapters for C-4??
Old 06-24-2003, 06:56 PM
Blue Oval Finatic
The adapters that you bolt to the transmission that make it a certain lenght to keep from having driveshaft modifications.
Jacob Middleton
