Ford rear diff ID help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2005, 09:09 PM
I am doing my first hot rod it a 1989 ford ranger. With a 351w HO on of a 1979 ford van. I found a rear end under a truck bed trailer it a 196? truck.
here is my problem i don't think its the right rear end out of the 196? truck. I would like to know if its a ford 8 inch 9 inch or what it is for sure. Here is the info off the tag on the rear end
wdw k
2 79 78c 833
its all so has the numbers 4025a on the center
I need all the info you can help me with THANKS
you may email me at chadesmart133@hotmail.com
please put BIGDUMMY in the subject because all email goes to my junk file
Old 07-07-2005, 05:21 AM
poncho62's Avatar
Wiki Edits: 5
moving to "Rear-end" forum....
Old 07-07-2005, 05:37 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Pictures?
Can we get a picture of this thing..? That may help..
OMT
Old 07-07-2005, 08:04 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I do not email responses. I post here so all people see the answers.
If you get a socket onto the bottom nuts that retain the center section to the housing..... it is a 8 inch.
If the socket will NOT fit around the center section / pinion gear area , it is a 9 inch type.
EDIT: I also edited the thread title. I like the thread title to reflect what the subject / question is
Old 07-07-2005, 09:04 AM
aka Duke of URL
Originally Posted by big boy
WDW K
2 79 78c 833
1967 FAIRLANE (Maybe COMET also)
2.79 OPEN 8" RG 28 SPLINE AXLE
AGREED!
Old 07-07-2005, 10:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
thanks KULTULZ
I know I can depend on a quality answer on the Ford stuff from you
Old 07-07-2005, 11:26 PM
thanks and i will try to get a pic
AGREED!
thanks for the help Iwill try to get some pic upload
if i can find out how.
p.s how do you post a new message
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
Jaguar Rear Diff Question Jag Daddy Transmission - Rearend 3 12-23-2003 10:47 AM
Cheap,Inexpensive Posi-Lok For Ford Rear?? nightrain_rod Transmission - Rearend 16 12-13-2003 01:36 PM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
47 ford rear end Barz51 Transmission - Rearend 2 12-06-2002 07:20 AM
