Ford rear disk help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2007, 06:41 PM
Ford rear disk help
Any thoughts here guys. Ford 9 inch with chevy bolt pattern. I want to get rear disks for it can some one tell me if its going to be a pain to get these and maybe a link.
Old 12-08-2007, 07:23 PM
powerrodsmike's Avatar
Wiki Edits: 161
Many aftermarket companies make the rotors with dual patterns...or can substitute the correct rotors. If they don"t, it is an easy matter to have them redrilled by any competant machine shop to the chevy pattern.
Brake tech solutions.
http://www.braketechsolutions.com/BTSV101/index.php
Master Power brakes
http://www.mpbrakes.com/
ECI
http://ecihotrodbrakes.com/rear_disc...nversions.html
HTH, mikey
BE different....ACT normal.
Old 12-10-2007, 05:49 PM
S10xGN's Avatar
Gotta love a turbo!
Here's my "low-buck" approach using 84-87 Corvette C4 front rotor and caliper assemblies on my 9" rear (small Ford end pattern and 5 on 4.75" bolt circle). The larger plate is 3/8" and adapts the C4 caliper bracket, the smaller plate is 1/8" and is a spacer to take up for where the (Ford) brake drum was. The brackets were drawn up in Autocad by my son and water-jet cut by a local shop for $40.00 (4 pieces). The pair of calipers, brackets, & hoses were $90.00 from an on-line junkyard, the rotors are new E-Bay jobs @ $90.00 a pair. Total in the rear brakes is ~ $260.00 with caliper kits, bolts, and new pads.
Russ
ID:	26074   Click image for larger version
ID:	26075   Click image for larger version
ID:	26076   Click image for larger version
Old 03-30-2008, 09:46 PM
Wiki Edits: 27
check out cad rear Disc
the cad FWD rear disc from the mid 80's have the chevy bolt pattern. I have seen guys put them on gm stuff ...also rivera parts should be the same as Cad ...some of the conversion kits for a 9 inch actually use the cad parts..
Old 03-31-2008, 10:00 AM
Irelands child's Avatar
My rear Wilwood 160-5844 rotor hats have at least 2 and probably 3 sets of holes. I would bet if you researched Wilwood's website you would find exactly what you need
These are mounted on opposite sides of the original Wilwood design for e-brake cable and plumbing issues on a TCI "A" chassis
Irelands child
Old 03-31-2008, 10:58 AM
Wiki Edits: 161
If you go the route that Dave is suggesting, get the part numbers from the wilwood website, then call Jegs or summit racing for the best price.
Pay attention to the hat to rotor mounting bolt circles as there are different patterns.
Also, order the mounting bolts, 1 kit for each rotor is required.
Later, mikey
Old 03-31-2008, 11:06 AM
Later, mikey
I'd recommend the entire kit - mine came from Speedway as an inexpensive close out - and the bolts are included. And as a note, even my part numbers have been superceded in their new catalog.
Dave
Irelands child
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
Ford 8" rear end Mel Smith Transmission - Rearend 6 09-10-2007 11:31 PM
Hey Ford Guys, HELP ID of Ford rear ?? 1939P7 Hotrodding Basics 10 07-18-2007 05:43 AM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
