Ford Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 06:46 PM
Ford Rear End
I have a ford truck rear end,tag has WDM-A1 OBB 3.50 8.7 318A can someone decode this tag . Or a least tell me what year truck rear end came out of. Thanks
Old 12-28-2006, 08:19 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I couldn't find WDM-A1 on the net.
it says it is a 3.50 non posi (posi would say 3L50, L for limited slip)
8.7 is the ring gear diameter..... I think the only 8.7s were used in 78-80 and I think in cars only. If it is a truck the spring pads will be on the top of the axle housing. If a car, the pads will be on the bottom of the housing.
318A is 31 day of A= January (B= Feb. etc., no "I" used by Ford, ever) ...... year of decade "8"
so probably 1978
If it is that 8.7 then it is an abortion that has no parts support and no gear availability..... If it is an 8.7 Dump it for an 8" from a Maverick or a Granada or a 9".
Old 12-28-2006, 09:02 PM
Ford rear end
I thank i made a mistake on id tag it should have read WDM-AD
Old 12-28-2006, 09:22 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Fordification says WDM-AD is a 9 inch with 28-spline axles 63-71 F100. 28 spline axles were common on cars (eg Mustang, Fairlane, Torino... etc) as well, where most of the "newer" trucks were 31-spline.
As xntric has pointed out, the tag info that you supplied says it's an 8.7" diameter, which I thought had a "WER" prefix. They had a non-removable carrier with a cover on the back.
Old 12-29-2006, 07:10 AM
aka Duke of URL
You need to remove, clean and save that tag. The exact I.D. is needed to identify it.
Old 12-31-2006, 04:40 PM
xntrik's Avatar
If I can find the 2 months ago thread about the 8.7 and 8.8 (different rear pan shape) that says an 8.8 was not used in the late 70s....... Eaton says Ford started using the 8.8 in 79 model year. I still swear I had a 79-80 Monarch (Granada) that had an 8.8 on leaf springs.
http://www.traction.eaton.com/prod5.htm
Kenrods, does yours have a tin cover on the back or is it a removable chunk?
Old 12-31-2006, 05:23 PM
66GMC's Avatar
Is this the thread that you were thinking of?
Don
Old 12-31-2006, 05:28 PM
xntrik's Avatar
Don
Ya, you found it about when I did thanks
Old 12-31-2006, 07:27 PM
It is removable
Old 01-01-2007, 07:53 AM
66GMC's Avatar
Here's another link that might help you to identify that thing.
Kevinstangs
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Ford Granada rear end tag identification CrashFarmer2 Transmission - Rearend 22 12-31-2006 05:23 PM
1955 Ford Wagon Rear End . . . TorqueU Transmission - Rearend 2 10-04-2003 11:33 PM
ford 9 inch rear end Nos General Rodding Tech 2 05-18-2003 07:37 PM
