The dually rearend is usually larger and heavier duty. The difference is the amount of lugs on the axle. dually's come with 8 lugs and single's generally come with 5 or 6 lug's. I have seen dually conversions in some catalogs with an adapter and/or rims providing you have enough clearance under the fender wells. I think it was JC Whitney.
If you don't go the adapter route I guess your next option would be get a 1 ton dually rear end off a ford. Right now I have a 1 ton dually rear end in my chevy with a single 8 lug rim. If I wanted duals, I would have to tub the bed for them to fit because I have a 3/4 ton truck with a pick up bed and then, I would run into issues with the outer tire sticking out of the fender wells.
Might not be an issue with the utility bed on your buddy's truck though.
The housings are the same. The lug pattern, SRW/DRW is 8, but the SRW has a 9/16 dia lug, the DRW, has a 5/8(or 3/4). The early F350 had a 1.062 nut across the flats, the current - 13/16. The DRW lugs are much longer to fit the double set of wheel web thickness. The drums/rotors are different.
This is a better site for those kinds of questions: http://www.ford-trucks.com/forums/index.php Yes, I have and have had for years, on and off, F350s (as well as 150s and 250s) as seen here : ![]() Dave W |
Of course there are the special fenders, innner wells, wheels, tires, machining the hubs for the longer and bigger diameter lugs ![]() Why screw around - there are complete rear's available - even Chebbies and Dodges would work with spring perch mods |
The Whitney dual adapters are junk. They are not rated for even a single tire load. I have Arrow dual adapters on my F350, no drama after 6 years on this truck, and 18 years on the previous truck. The Arrow adapter is piloted on the hub, so nothing can loosen up. They are not cheap, the adapters are $600 for a rear axle without fenders. They do come with new lug nuts and instructions for installing them. I have has as much as 12,000 lbs on this truck for short distances, and they have never come loose.
| List all of your cars HERE! | Carbed95GT | Hotrodders' Lounge | 289 | 11-09-2011 06:43 PM |
| ford 9'' rear end in a nova | Sagacious | Suspension - Brakes - Steering | 2 | 12-27-2007 09:10 AM |
| Ford 8" rear end | Mel Smith | Transmission - Rearend | 6 | 09-10-2007 11:31 PM |
| Gears for a stock Ford rear end??? | haley72 | Transmission - Rearend | 6 | 03-25-2007 10:45 AM |
| 1955 Ford Wagon Rear End . . . | TorqueU | Transmission - Rearend | 2 | 10-04-2003 11:33 PM |
