ford rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2012, 04:38 PM
ford rear end
I am trying to ID the rear end in the 47 ford I just dot I was told it is a 75to78 Ganada I need to ID it to find out what other cars the parts will interchange with I need all the parts for the parking brake every thing has been removed can any one help me thanks Jack Sr
Old 12-20-2012, 05:01 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Are you familiar enough with Ford rear ends to tell the difference in a 8" and a 9"? A 75-78 Granada should have had a 8" ford rear, looks a lot like a 9" ford rear end, but the bottom two bolts of the center section will be accesible with a deep well socket. A 9" rear end the bottom two bolts on the center section have to be taken out with a wrench due to the offset in the pinion. I will try to get a picture of a 8" ford rear that I have and post it for you to compare. Hope this helps a little.
Old 12-20-2012, 06:01 PM
Try this link It has a lot of good information that should be helpful in figuring out what you have. I also stand corrected a 77-78 Granda could have had a 8" (removable third member) or a 8.7" non-removable carrier (looks similar to a 8.8). http://www.crankshaftcoalition.com/w...identification Hope this helps.
Old 12-20-2012, 06:13 PM
Wiki Edits: 27
Versaille 9
Verry verry Few used the 9 in disc brake versaille, rear. also an option on mercury monarch. It might be a good time to upgrade with a rear disc kit. or mid 80's town car brakes. or explorer rear discs.
Old 12-20-2012, 06:19 PM
I have learned something else lol I never knew that the monarch or Granada came with the disc brake 9". That was more often found in the Lincoln cars of the day wasn't it? Or was it an option for all three and just not oftne used in the ford and merc?
Old 12-20-2012, 06:46 PM
prostreet6t9's Avatar
Differential/Driveline
Can you post a pic?
Old 12-20-2012, 06:49 PM
Wiki Edits: 27
( rears
I am pretty sure It was standard on the lincoln. and all the ones with the 9's also use hydro-boost power brake systems.
all the ones i found in the bone yards had lots of options. factory aluminum wheels, power windows. door locks, different dome light with pull down map lite etc. 2 doors usually had bucket seats and a console.
The Following User Says Thank You to timothale For This Useful Post:
carolinacustoms (12-20-2012)
Old 12-20-2012, 06:55 PM
Wiki Edits: 27
versaille 9's
The Versaille and option granada -monarch 9.s were unique, replacemant parts are hard to find, the wheel bearing retainer was also the caliper bracket . NEVER buy one unless it is complete, replacement rotors and calipers are available. A tow truck driver drug one for a ways and ruined the caliper bracket, I looked long and hard and passed it by.
Old 12-20-2012, 08:20 PM
I wanna say maybe some of the T-birds of that era came with them also? Not for sure on that but seems like I remember working on one for a guy several years ago.
Old 12-20-2012, 11:50 PM
Wiki Edits: 27
big lincoln ?
the 9 3/8 with Discs were optional on big lincolns, wider and a 5 on 5 wheel pattern.
Old 12-24-2012, 10:46 AM
thanks
thanks for the help
1948 Ford stock engine/tranny with Ford 9" rear end beek15853 Transmission - Rearend 5 04-04-2012 08:56 PM
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 11:19 AM
36 ford rear end jerryb Transmission - Rearend 6 10-13-2006 10:24 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
47 ford rear end Barz51 Transmission - Rearend 2 12-06-2002 08:20 AM
