Ford Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2005, 04:07 PM
Ford Rearend
I have a Ford Rearend in a custom car and need to know what year and model ETC it is so I can order parts for it. Can anyone help me. Following are the numbers that I got from the rearend when I took it apart.
Standard Rearend Not a Posi Track
Ring Gear 32 Tooth ( USA-WAC-4210-A 9-744 Shift No 2 is on the gear )
Pinion Gear 9 Tooth
Yoke Seal Number is National 6930
Pinion Housing has number 4668 B Cast in it.
Pumpkin Housing Numbers
Bottom of Housing 55
Left Side of Housing DIF 4
Top of Housing 2D9 F
Inside of Housing C CIAW 12
4025
Thanks Bob
Old 10-15-2005, 05:08 PM
Wiki Edits: 31
All I can tell you is it is a 3.56 ratio
Old 10-15-2005, 06:37 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
Check out http://www.kevinstang.com/Ninecase.htm
Has a lot of info about how to ID a ford 9 inch. Good place to start and know what to look for.
Ford vs Chevy question savman1 Engine 31 10-14-2008 07:13 PM
ford rearend in a chevy jo5hi3 Transmission - Rearend 2 12-06-2003 11:11 AM
Ford 9 inch rearend Nos Transmission - Rearend 2 05-21-2003 07:39 AM
40 ford rearend 49burb Transmission - Rearend 7 05-19-2003 11:53 PM
ford rearend for 33? nick Transmission - Rearend 2 11-06-2001 10:58 PM
