ford rearend installed in 1956 chevy car???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 02:31 PM
I have 1967 ford fairlane rearend that i would love to install it under my old chevy. I would love to have some info from all that may have taken on this kind of project before> thanks
Old 08-09-2006, 09:42 AM
Last journal entry: Robs34 - Done my dash
Heres how I do them. Take out the old rear end and measure the distance between the centre bolts on the rear springs (take both measurements from the left side of the bolt will give you dead centre) draw a line at this distance past the pad area directly on the spring. measure the same distance on the new rear end and grind off the welds holding the old spring pads on if they are not the same distance making sure you dont dig into the axle tube itself. Next take the Chevy spring pads off the old rear end without digging into them, tidy them up and sit them back on the spring . With help put the new rear on to the old spring pads and measure and check the distance marked before. Measure from this point to the back of the backing plate and shift the rear axle until the measurements are identical on both sides, check the position on the chassis as well . Next you need to set the angle of the diff. you need to put the car on stands under the springs at the back and lift the front end and put it on stands as well so it is level. Hire or borrow an angle guage and set the pinion to 3 degrees. recheck ALL your measurements and TACK weld one side, measure again and do the other side. Then take the whole axle to a welder who knows that you have to be careful welding the assembly so it doesn't warp. A new tailshaft, adapt the handbrake and the rear brakes making sure the wheel cylinders match your system and you are done. Easy huh !
Good Luck
Rob.
Old 08-11-2006, 10:05 AM
ford rearend in 56 chevy
Hey Rob, Thanks alot for the info. I'll put it to good use. BY the way, extra nice pics of your rides. I'll let you know how the installation goes when done. Thanks again jmoon2 (john)
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
Looking at project cars, 42 chevy, 55 desoto, 59 ford truck among others Wmarden Hotrodders' Lounge 8 02-08-2005 05:19 PM
1954 Chevy car rear end swap help! gunner_xm192 Transmission - Rearend 1 10-18-2004 02:17 AM
