Ford recalls 08 diesel trucks, Flaming exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 09:15 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Seems the 08 Ford diesel trucks have a problem with a flaming exhaust.
http://www.forddoctorsdts.com/articl...icle-07-01.php
Old 03-27-2007, 08:52 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
When we had to do those recalls it was a pain in the butt day. When those trucks first came out and we had to go to training they told us that the egt at the tip can reach 1500*. If you every see one thats why it has that funny looking tip on it. It is ment to swirl the hot exhaust air with fresh air around it. The first thing they told us is when people start putting exhaust systems on these and get rid of that tip it would be hot enough to burn the paint off your car. This is from the ford classes so they new there was a problem all along.
Old 03-28-2007, 12:29 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
I must be missing something.
From the article: "The 6.4L Power StrokeŽ engine achieves and regulates this heat by injecting small amounts of fuel during the exhaust stroke as it monitors the exhaust temperatures though the use of three temperature sensors located in the exhaust system."
Doesn't that seem like a waste? Surely they're working on ways to make it more efficient so that (a) there are less ~burnable~ particulates in the exhaust to start with and (b) there's no need to squirt fuel anywhere it's not used to produce power.
Old 03-28-2007, 09:18 AM
1969NovaSS's Avatar
The reason they shoot diesel on the exhaust stroke is so it will create extremly high egt's. It is meant to clean the particulate trap so it will not clog up and cuase a big loss in power.
Ford 390 exhaust arwestlund Engine 3 06-07-2003 07:15 PM
34 Ford exhaust options??? Pilot34Coupe Engine 1 02-14-2003 02:32 PM
64 + 65 ford trucks vern Body - Exterior 5 01-22-2003 08:03 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
custom exhaust for 36 ford coupe bomo Engine 5 12-07-2001 04:49 AM
