Ford relay ratings? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-30-2007, 05:13 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by oldred
The question about a relay for an auxiliary fuse panel is for another project and the fuel pump was my big concern here. I was told by someone local that the EEC power relay was rated higher than the fuel pump relay but I was a bit skeptical that was the case and apparently it is the other way around.
Thanks again everyone.
Doc here,
For ANY AUX type fuse panel, you really want a continues Duty SOLENOID..not a relay..
Where the contacts are rated in 100's of amps not in amps..
There ar several good type Marine or Electric Forklift type solenoids around to serve this purpose in Continuous operation...a Ford type solenoid WILL NOT work..it will overheat and fail.
Also , on ANY relay, PROVIDED, it has the same pin count/operation, (NC, NO, CW) but the pins won't fit a stock type relay socket, you can build a "Gender Bender " to a Bosch Standard relay (That you can get anywhere for $4.00), simply by using the provided Relay SOCKET, (for the Bosch) and after confirming the pin operations on both, using a Bandsaw OR Sawzall, carefully cut and REMOVE the plastic cover off the relay, (Stock relay) about 1 ~ 1/4 inches UP from the base of the relay, and just IN enough to separate the PLASTIC..Don't cut the relay.
To be sure of Function follow the contact and coil wires out by sight, make a note , such as : Pin 1 = Coil (Ford) Pin 85 = Coil (Bosch) , Pin 3 = Center wiper (Ford Relay) Pin 30 = Center wiper (Bosch) .. and so on..
Then remove the mechanical relay from the bottom of the relay socket (unsolder) and using the proper gauge wire, and your notes, wire the two "sockets" together..The Bottom (Male pins) will mate to a Ford Harness, the top (Female socket) will accept any Bosch standard relay.
You can cover it in LARGE heat shrink tube, Or fancy it up and epoxy it between the sockets in a jig so it looks just like a relay ..or just tape the center up..(the easy way..)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #17 (permalink)
Old 07-30-2007, 08:05 PM
Thanks, I do want this thing to be neat and that sounds like a great idea.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 07:00 PM
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 07:10 PM
Ford Alternative Restomod Article datson280zxturbo Hotrodding Basics 1 05-31-2006 04:18 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
