Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford relay ratings?
Old 07-27-2007, 11:45 AM
aka Duke of URL
Originally Posted by oldred
1987 Mustang LX 5.0
One is a fuel pump relay-E3TB-9345-A2A
The other is a EEC power relay-E3AF-12A646-B2A
Another nearly identical EEC power relay I have has almost the same number and fits the socket-E3(A?)12A646-B1A/7ED
Unknown application Ford relay-E4LB-13A025-A2A
I am assuming that is one part number for each but it is arranged in three numbers (hence the dashes) vertically on the case, for space reasons I assume.
Sorry it took so long...Milk of Magnesia took a while to cut in this morning...
The FORD MPC has a master Relay I.D. Changeover but does not give the AMP ratings. If the relay is not actually marked regarding it's rating, you will have to go to a wiring diagram. Thought I could cheat but no.
The E4LB 13A024-A2A is a LINC headlamp dimmer relay.
