Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford relay ratings?
Old 07-29-2007, 07:20 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
I went to NapaOnLine.com and entered those Ford engineering numbers into the [Non-Napa Part Number] field and pressed [Go] ...
These are the results.
# E3TB 9345 A2A -- Fuel Pump Relay
Napa Echlin Part Number: AR-240
Attributes:
Features & Benefits:N.O. Terminals 3-4 @ 35 Amps; N.C. Terminals 3-5 @ 20 Amps; Coil Terminals 1-2
# of Terminals:5
# E3AF-12A646-B2A -- EEC Power Relay
NAPA Echlin Part Number: AR-242
Attributes:
Features & Benefits:N.O. Terminals 3-4 @ 25 Amps; N.C. Terminals 3-5 @ 15 Amps; Coil Terminals 1-2
# of Terminals:5
Just for fun ... I also went to www.Motorcraft.com (Ford's own) and tried to c/ref them there ... and no go!
I used to sell a ton of both of these relays, and used to know the Motorcraft numbers off the top of my head ... but that's gone now.
These relays are used for a multitude of different applications and functions.
For example, 87-91 F-Series pickups used one of each side-by-side under the hood for fuel pump/EEC purposes as well.
Edit / Add-on:
Regarding the suffix on those Ford engineering numbers (-A1A, -A2A ... etc)
The DIGIT (1,2) an usually be ignored. It usually indicates a minor revision or a supplier change. In other words ... E3TB-9345-AA is the same as "E3TB-9345-A1A and A2A".
