ford roller rockers on sbc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2012, 05:25 PM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
Will sbf roller rockers aftermarket, fit and work on a sbc? Vice versa
Old 04-23-2012, 05:42 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I could see why you would want Chevy parts on a Ford but Ford parts on a Chevy????? But seriously, why on earth would you want to do either?
Old 04-23-2012, 05:46 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have seen some guy's run chevy rockers on a ford engine before, so i am thinking some will work but may be some difference in the push-rods though.
Why not just go ahead and get the proper rockers to start with ?
Cole
Old 04-23-2012, 05:49 PM
I have a free pair so wanted to see if I could make use of them.
Old 04-23-2012, 07:50 PM
Irelands child's Avatar
Best check that actuating ratio first as many SB Chevy's start at 1.5 while the SB Fords start at 1.6 (general rule of thumb). Then there are the several ways to fasten to the head - stud, stud with limiting land(Ford), bolt down (Ford). Next - push rods may require a special length. Then, the actual arm physical sizes might be 'off' as far as for the valve stem fit to push rod relationship. For free - I might spend some time looking at the two, but not much as roller rockers usually wont make or break a budget nor are really needed for a mild performance engine
Irelands child
Old 04-23-2012, 08:14 PM
In simple terms, no, the geometry will be off, requiring other changes to make the Ford rockers "fit" correctly.
They will, however, be very close on an AMC or Olds motor.
Project89's Avatar
we tried putting some ford rockers on a 3.1 60* chevy v6, these engines use the same rockers as the sbc.
i belive the set was a ford 1.7 ratio roller rockers,while they would work for a lil bit the geometry was way off. ill have to find the posts i put up on the other forums as it has all the specs and pics in it. when i find it ill post some of the pics and make sure what the specs on the rockers were,but im pretty sure they were 1.7's
Old 04-23-2012, 08:24 PM
WDCreech's Avatar
Grumpy Old Goat Herder
SB Ford rockers will work on traditional Pontiacs, but SB Chevy's won't, so it is unlikely that the Ford rocker will work on a Chevy.
Old 04-23-2012, 08:29 PM
Good to know.
Old 04-24-2012, 02:09 AM
[QUOTE=eloc431962]I have seen some guy's run chevy rockers on a ford engine before, so i am thinking some will work but may be some difference in the push-rods though.
Why not just go ahead and get the proper rockers to start with.
Because some ford engines just can, most used pedastals. non adjustable rockers. My pantera has Boss 351 heads, the same screw in studs as a BBC chevy, the ratio is super close (1.71-1.73) the BBC crane aluminum roller rockers work great on my 351C. ten years and running the pantera with the BBC crane roller rockers under the 351 covers.
I'm a chevy guy i work on C2 vettes, but loved the pantera, thAt thing is like a go kart on steroids...
Old 04-24-2012, 04:52 PM
eloc431962's Avatar
Wiki Edits: 37
[QUOTE=techron]
Thank's tech, oh and i had my hands on a pantera back years ago now i wish i went ahead and got it.
Cole
WYSCO sbc Roller Rockers- anybody? GRIdLOCK Engine 1 11-09-2010 06:13 PM
SBC Roller Tip Rockers? mcmoore Engine 2 05-16-2010 11:15 AM
SBC adjusting roller rockers. pittbull7934 Engine 27 10-05-2009 06:30 PM
SBC 350 Roller Rockers colincamaro Engine 11 10-04-2007 01:22 PM
roller rockers for sbc 350 70ChvyNova Engine 4 12-05-2006 11:24 PM
