There used to be a few guys around here that raced GM inline six's at the local dirt track and raped a lot of the V8 guys. This was well before my time, but I used to date one of the guy's daughter. I've seen some of their intakes, wild stuff and really interesting designs. I'll try to get a couple pics of them if I can.
I bought a '36 Ford Tudor a while back and was considering going with a turbo 250, but I started back on the Chevelle. |
my suggestion would be to shoot for 220 HP Naturally aspirated.. which if you'v read any of the tech faqs. that's pretty easy to get with the alloy cylinder head.. basicly you need to bump the compression, and you do that with the flat top pistions. once you get the compression ratio a little higher, which you can do by cutting a little off the cylinder head.. mike will know how much to cut if you ask him. he has the company leave a little extra 'meat' on the deck surface to make up 57cc chambers, but with a very light cut, they go down to 55cc, and you could go more if needed. but don't in case you ever want the engine force fed.
with 220 hp, your still going to have a lot of torque, and it'll have more power than you expect, and it will be over 200# lighter than a comparable 5.0L 302 |
Its hard to compare that to a 302 when you're looking at 220hp... a decently built 302 can double that.
IF I stayed with the 6 I would turbo it for sure, and seriously consider EFI. Those two things can turn your inline six from an embarrassment to a show piece. |
forget Napa and autozone, if you want literature use AMAZON.com. I am not affiliated in any way with them other than I have bought about 50 car books through them.
Falcon 6 handbook.. it's a little outdated but the information is still solid
http://falconperformance.sundog.net/order.asp authors are also on www.fordsix.com. I use Amazon also, and you'll want to buy a couple books on turbocharging also I would reccomend the yella terra full roller rockers. there very- very high quality, but they also save HP, and will hold higher RPM's better/ fully adjustable.. there have been problems with the cheaper 1's, and that cylinder head at least deserves a roller setup.. Last edited by matt167; 04-09-2010 at 02:50 PM. |
We have some pretty unique Ford inline 6 cylinder engines over here, all are Ford Factory production engines, mass produced in large numbers, and relatively cheap (for what they are) from junk yards in Australia. They are not rare high performance engines as you might expect, but STANDARD Australian Ford factory engines never seen in America. They range from iron 12 port crossflow heads, alloy 12 port crossflow heads, up to double overhead cam engines with 24 valves, and a factory turbo. The latest DOHC turbo 244 inch engine is factory rated at 420Hp with 417 ft/lb torque, and can easily produce more than that with higher boost from the standard GT35 ball bearing turbo. http://en.wikipedia.org/wiki/FPV_F6 All these engines would be a straight bolt in. Last edited by Silver Shadow; 04-09-2010 at 06:10 PM. |
| Questions on the Ford 4.6 DOHC and 5.4 DOHC | Nightfire | Hotrodding Basics | 21 | 09-25-2011 06:15 PM |
| Decoding an engine Ford FE | RideQuality | Engine | 24 | 01-24-2010 11:22 AM |
| Knowledge base | Dave57210 | Hotrodders Site Suggestions and Help | 2 | 12-20-2009 07:06 PM |
| 1985 C-6 truck tranny, no engine braking effect | fast68 | Transmission - Rearend | 40 | 02-04-2008 05:55 PM |
| Unknown Ford 460 engine | Stovens | Engine | 3 | 10-28-2007 07:58 PM |
